I have a question regarding a gas turbine application, where the exhaust gas goes directly to a dryer. The dryer needs certain amount of power to dry the clay, 7,500,000 kcal/h. I need to calculate if the exhaust gases of the gas turbine can produce it.
How can I calculate it? I am preparing a first estimate economic analysis, so I don't need it that detailed.
Dryer: 7,500,000 Kcal/h
Temp required: 600 C
Gas Turbine:
Fuel Consumption:132 mmBtu/hr
Flow rate: 181 ton/hr
Exhaust temperature: 500 C
Can I use the equation: P=mCp(T2-T1)
How can I figure this out?
THank you very much
Gas Turbine:
THank you very much
