gas expansion calculation
dmrgt03
Chemical
I am flowing 100 sccm gas through 10 orifii of diameter 0.016". The gas is either B2H6 or BF3.
I want to do a gas expansion calc to determine a minimum pressure gradient needed to establish a sonic front.
Are you stating that the flow is choked? If the flow is adiabatic and secondaly a perfect gas with constant specific heats, then stagnation Temp must be stated.
To determine the pressure drop, either upstream stagnation pressure or downstream static pressure must also be given.
If we are talking ideal gas, isenotropic flow, with M=1 then clearly it is choked flow. Stagnation temp would be 300 K.
In this case, downstream static pressure is 6, 8, or 10 mTorr.
For choked ISENTROPIC-flow-perfect gas, constant specific heats
The crictal pressure ratio of upstream STAGNATION PRESSURE to downstream STATIC PRESSURE =
[(GAMMA+1)/2] RAISED TO POWER [1/(GAMMA-1)]
WHERE GAMMA IS RATION OF Cp/Cv
