Hi everyone-
I have a question about pressure control. I have to design a system that will use a gas booster (with two pistons) to control the pressure. I've only used gas boosters in one other design, and it was with a constant supply pressure. However, this design is going to be working with a manifold to supply the gas to the boosters, and the manifold is not at a constant pressure. It varies depending on the amount of air supplied. Can anyone think of a way to design the system so that the air being supplied to the gas booster can be regulated to a constant pressure?
Thanks!
Thanks!
