I currently conduct investigations on Power Influence and Noise Metallic in telephone exchanges throughout our company. I know a good deal about Telephone outside plant engineering, but my commercial AC power theory is in need of some assistance. I use a Spectrum Analyzer and a wand to detect faults that could cause influence in the telephone cables. Most of the time these faults are ran down to either open cable shields, which is something we as a telephone company can repair by properly bonding and grounding our cable, but on some occasions the problem is found to be coming from a capacitor bank or defective transformer.
I have been trying to get a power engineer to explain what exactly a capacitor and regulator do for the power Companies facilities, but they seem a little relentless to share any information. Correct me if I’m wrong but a capacitor increases the voltage/ amperage on a line and a regulator regulates the voltage on a line? The down side to this is when the PSC (Public Service Commission) conducts an audit of an exchange and finds high Power Influence readings the Telephone company is the one responsible for finding the problem, even if it the power company causing the influence. I figure the more I can learn about the AC power designs the better I will be able to troubleshoot these problems.
We currently have a location that has been under investigation for several years. We have had the power company in the area remove all the capacitors from service and still have the same problem. The spectrum analyzer leads us to believe the influence is coming from the sub-station in the area. Can the Sub-Station produce this type of influence? Any help would be greatly appreciated.
