slickdeals
Folks,
Can a truss with CJP welds between the diagonals and the chords still be analyzed with diagonals being pin-ended members?
For example, the chords are W14 (web-horizontal) and the diagonals are also W14 members with their flanges connected by full penetration welds.
1. Can the truss be analyzed and designed using moment releases at their ends?
2. If the moments at the ends are not released, is it okay to use an effective length factor of 0.65 in their design for compression (assuming a column with fixed ends).
