rickt
- Jun 4, 2001
- 1
I am using a nord 20hp gearmotor with a Siemens MM440 invertor in a hoist application.(With encoder feedback and resistor for regen) The system can lift 9000 lbs at over 8 inches per second in normal operating mode. When is comes to holding the load at close to zero speed, it can only handle 5000-6000 lbs before the platform looses control.
(Specs - Gearmotor Torque 13000 in lbs at 97 rpm)
Question:
Shoudn't the system be able to generate full torque at zero speed. (I am using encoder feedback for closed loop vector)
Is the motor undersized? I do not want to put blame on the invertor supplier if it is a motor problem. The VFD specs claim that my config can produce full torque at zero speed. (200% for a small period of Time)
Question:
