MechNorth
- Nov 11, 2005
- 1,706
A long time ago, in a thread started before I joined Eng-Tips, someone initiated the debate over whether a drawing needs to be completely GD&T'd or not. Clearly each supporter of the rival factions has their own reasons for their assertions, but I'd like to see them listed, defended & debated in a logical & hopefully standards-based manner. I'm not naive enough to believe that this will launch everyone over to one side, but it should give us all some perspective as to what the other side of the wall is thinking and why.
So here goes ... I'm for an essentially complete product definition using geometric controls tied back to datums where possible. The exceptions where conventional tolerances would be used as listed in Y14.41 Table 8-1 are:
1) Fillets, Rounds & Chamfers
2) Reliefs, Step Surfaces (I don't particularly support this one; surface profile is more concise)
3) Countersinks
4) Oblique Surfaces
5) Entry Depth and Spotface
6) Remaining Thickness
7) Notches, Flats, and Pin Heights.
Now, if you look at the Note in Section 8.2 of Y14.41, it indicates that the list is not exhaustive, but rather indicative to similar and other valid applications. While it doesn't explicitly preclude the applicability to position dimensions, such application would be contrary to the indicated application methods of such controls which are restricted to attachment to size callouts, directed leader to the feature (surface), or on an extension line from the feature.
Also, from an engineering perspective, I want to remove ambiguity from my documentation, so that many featues such as weight-reduction holes, non-functional outer geometries, etc. are at least related loosely back to my DRF. Ambiguous documentation cannot be defended in court, and that is a growing reality in industry today as margins & survival dwindle.
Et tu?
Jim Sykes, P.Eng, GDTP-S
Profile Services TecEase, Inc.
3) Countersinks
4) Oblique Surfaces
Et tu?
