Everything leaks. It's just a matter of degree. Just like there has never been a physical round hole or a flat plane. These are mathematical concepts that are not physically realizable. If you have sensitive enough instruments you can measure the leakage of any valve.
There is no shut off valve, the rail is supposed to maintain pressure when the engine shuts down. As a rule, leaky fuel injectors are quite rare these days, the primary failure mode is contamination. A soft seal may or may not be less susceptible to failure from contamination. Hard contamination may damage a soft seal but eventually work it's way out of a hard seal.
From my experience at least 75% of the automotive fuel injectors that are replaced have no failure at all. Some of these may have been replaced because one was bad and the labor charge is basically the same to replace them all. Others are replaced because the mechanic (parts changer) has no idea what is wrong and is just changing one thing after another. A lot are replaced because someone is trying to make a boat payment.
I'm curious, what was the problem that was supposedly caused by your leaky injector and how did they diagnose it?
