Call the local nuilding code office. They can tell you what the local requirements for footings should be. - That would give you a good idea for the top of a sump.
Your local water authority e.g. will likely be quite familiar with “frost depth” (I believe there is a geographical map of “extreme frost penetration” contained in D100-05 "AWWA Standard for Welded Carbon Steel Tanks for Water Storage").
