Komodo86
- May 2, 2011
- 74
I have done a fair bit of mathematical and 3D modelling of independent automotive suspension systems, and have come to the conclusion that the in pure steady state cornering no matter what the combination of springs, ARB/sway bars, motion ratios or linkage geometry, the roll angle (ignoring the tyre flex component) is always determined by the deflection of the spring and that the load they see on each axle will directly correspond to the rate of the spring, meaning that they will deflect such that the wheel movement and thus roll angle, is the same at each end of the vehicle.
It has been suggested by an experienced engineer, that this is not the case and that the front and rear axles DO roll different amounts, however the mechanics of this were not explained. Surely if such a case was true, this means the chassis must be twisting to accommodate the difference in roll angle? In a typical modern chassis with say 15,000Nm/° torsional rigidity, surely the amount of differential roll, if any, must be negligible to the point of not being worth considering?
