Friction Loss thru an Orifice
Greenlight
34
I'm trying to find the overall friction loss (f) in a complex circuit. I have the pressure losses at each junction and can find "f" in the parallel and series portions of the circuit.
There are two orifices in the circuit.
I know the mass flow rate through the entire circuit, the mass flow rate through each orifice, the pressure drop through the orifice(s), pipe diameter, and orifice diameter.
I don't need head loss, I need friction loss.
This is related to a heat transfer problem where I'm trying to find the overall thermal performance (relationship between Nusselt number and friction loss).
Any help, guidelines, sources for info., etc. will be appreciated.
I didn't think there was a relationship between Nusselt number and friction. Nusselt is a relationship between the heat transferred by convection and the heat transferred by conduction in a given system. Heat transferred by friction is the thermal equivalent of inefficient mechanical work.
"The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward X-CEO BP
"Being GREEN isn't easy." Kermit[frog]
In turbine blade internal cooling the overall thermal performance is:
(Nu/Nuo) / (f/fo)^1/3
where Nu is the Nusselt number for a passage with enhanced cooling. Nuo is a passage with no enhancements.
f is the friction factor with enhancements.
fo is the friction factor with no enhancements.
Again, any help will be appreciated.
