Frequency drive used for single phase motor? 1
bigham
Is it possible to use a frequency drive to make a single phase electric motor run at variable speeds and would you run into trouble with the xtra phse from the drive with no load?
"Is it possible to use a frequency drive to make a single phase electric motor run at variable speeds..."
You can use a single phase VFD on certain types of single phase motors, check out Anacon Systems.
Keep in mind that you should not use them on capacitor start msingle phase motors, which unfortunately is the vast majority of them.
"... and would you run into trouble with the xtra phse from the drive with no load?"
Yes, that is why you will not be able to use a 3 phase VFD on a single phase motor.
"Venditori de oleum-vipera non vigere excordis populi"
In addition to not being able to use capacitor start motors, you also can't use split phase motors with a VSD, or not below a certain (motor-specific) frequency, because the reduction in speed will cause the centrifugal switch to close and energise the starting winding. This winding, being short-term rated, will then overheat and damage the motor.
Start each new day with a smile.
Get it over with.
Thanks for the explanations, very helpful.....I knew I was missing something
Thanks again
ScottyUK
Never thought of that, but it makes perfect sense. I learned something new today, thanks.
