We are in the process of designing a crane footing (10ft. square)on controlled fill (20 ft of fill with footing embedment of 5 to 10ft). My primary concern is settlement since the applied loads are in the range of 2 tsf and bearing should not be an issue. I ran an analysis assuming a sandy soil compacted to both 90% and 95% modified proctor yielding a relative density of 50% and 75% respectively and an assumed modulus of 365 and 626 tsf respectively as well. Using Schmetmann I calculated acceptable settlments of about 0.5in to 1.29in. and was going to recommend that the fill (up to 20 ft thick) be plaaced in 8in. lifts to 95% (about 0.5in).
Is this reasonable, are the construction recommendations reasonable, any comments would be greatly appreciated.
