AlpineEngineer
I've got a single family home foundation plan that I am designing. The site is SOLID exposed granite bedrock, no fractures, it will need to be blasted. The slope is about 30% and the house will be 1 story on top of a walkout basement, so slab on grade. For now I am assuming that after blasting and excavation we will be on undisturbed solid bedrock. It appears to me spread footers are not necessary due to the fact that there will be no frost heave potential and the bearing capacity is probably around 12,000 psf (plenty).
Couldn't you just pour the slab directly on the bedrock and build up from there? I'm thinking of using an 8" thickened edge/slab w/ horizontal #4's at all load bearing areas, for concrete integrity. I am also thinking I'd feel better if there were some dowels (#5 bars) epoxyed into the bedrock and then bent into the slab, is this needed? If so, how often would you put the dowels, how deep?
Thanks in advance.
Thanks in advance.
