form cutter 1
punkey
hi
can anyone help me in how to create a form cutter milling in ug nx
thank u
In NX7.5 you can check in the documentation -> Manufacturing -> Manufacturing Milling -> Tool -> User Defined Milling tools.
I attach a pdf with this pages of the NX7.5 documentation.
Frank.
 http://files.engineering.com/getfile.aspx?folder=d39b66ce-cac4-4f88-8b5f-6abe8aaf63c5&file=User_defined_milling_tool.pdf
thanks frank
iam working on that
regards
punkey
If you want a chamfer or corner rounding cutter, retrieve all the ones in the tool library and look at those. You may find something close to use as a starting point.
Mark Rief
Product Manager
Siemens PLM
