dogarila
- Oct 28, 2001
- 594
Suppose I have a C-frame with the base on the ground. There is a hydraulic cylinder on the lower side of the C pressing a tube into a part clamped and supported at two locations by the upper side of the C. The cylinder force is 10000 lbs. How should I describe the loads to do a quick FEA of the frame in CosmosExpress? Just a general idea.
1. Base fixed and the whole force in the centre of the upper side of C?
2. Base fixed and the force divided in two applied at the support locations of the upper side of C?
3. Base fixed and half of the force applied to the upper side of C and half to the lower side of C?
4. ???
Thanks,
4. ???
Thanks,
