For specific or detailed information you may need to talk to an ocean engineer. The base water level during a hurricane may rise (storm surge), assuming waterway is connected to the ocean. In open water, the wave height & period that is generated is a function of wind speed, wind direction & duration. Waves are modified (higher & closer together) as they approach shore and water depth decreases. You may be able to find this "design wave" information for your location, try the local officials, disaster or hazards documents.
Forces can then be estimated for a design wave height. Will depend on pile/pier diameter, primarily. The "Shore Protection manual" by the Corps of Engineers will cover all this.
