Evening All,
I'm after some guidance on how I calculate the force required to bend a piece of aluminium.
Basically, I want do design a device that will bend a 1mm thick piece of aluminium, about 500mm wide in to a U channel shape. I plan to use tool which is a U channel shape die, and a form tool that will slide in to the side and shape the aluminium in to the channel.
Any help would be hugely appreciated
Russ
Russ
