Hi all,
I'm having some difficulty reconciling the loading for the following scenario and was hoping for some help.
I have a Y-shaped structural member (looks like a tuning fork or motorcycle rear swingarm) with the "legs" of the Y rigidly attached to a rotating shaft. Overall length (or height) of the Y is approximately 48", and the spread of the legs is approximately 12". The Y-shaped member has an applied external load at its end, causing a moment about the axis of the rotating shaft (i.e. with a 48" long moment arm).
Is the moment where each "leg" of the Y attaches to the shaft is simply 1/2 the total moment? I'm thinking about what the moment diagram should look like so I could consider torsional loading on the shaft.
Additionally, if I had an opposing moment applied to one of the legs (for example, via a gear which was mounted rigidly to one leg), what moment load (if any) would exist at the other leg, and would there be torsional loading of the shaft between the two legs?
I hope the above description makes some sense, and thanks in advance for any help.
Ewan
Ewan
