For API in MATLAB, how to migrate from SAP2000 v14 to v21
zhddz
CN
I updated my SAP2000 from v14 to v21, and found that my old MATLAB API code doesn't work any more. I'am trying to update my code, and got stucked.
My original code is like this:
ret = SapModel.PropLink.SetDamper("D1", MyDOF, MyFixed, MyNonLinear, MyKe, MyCe, MyK, MyC, MyCexp, 1, 0);
The code sets damper properties. It worked fine in SAP2000 v14, but doesn't work in v21.
MATLAB displays error: No appropriate method, property, or field 'GetDamper' for class 'SAP2000v1.wPropLink'.
Then, I change the code to this:
PropLink = NET.explicitCast(SapModel.PropLink,'SAP2000v1.cPropLink');
ret=PropLink.GetDamper("D1", MyDOF, MyFixed, MyNonLinear, MyKe, MyCe, MyK, MyC, MyCexp, 1, 0);
Doesn't work neither.
MATLAB displays error: No method 'GetDamper' with matching signature found for class 'SAP2000v1.cPropLink'.
I do not know what to do next, please help!
I use the etabs api and sometimes with new versions, I have found that the csi won't completely update their compiled html help docs.
Does matlab have a help function, when I run into trouble I use the help function:
python code:
help(SapModel.PropLink.SetDamper)
If you use in Matlab:
help SapModel.PropLink
does it return a statement?
Hello, rscassar:
Thank you for your help!
I've tried:
and it returns:
SapModel is a variable of type SAP2000v1.cSapModel.
and help PropLink returns:
PropLink not found.
I still do not know how to fix the prolem.
