I'm designing a footing that is more of a grade beam that carries moving loads.
I have pos & neg moments, but the locations and incidences of the moments vary...
For example, varying the position of the loads may produce a small negative moment and a large positive moment simultaneously in the beam.
If I place the loads near the end of the beam, it produces a large negative moment and zero positive moment.
1). Is it proper to design top and bottom reinforcing separately for the worst case positive and negative moments?
2). Should I be designing this as a doubly reinforced beam?
Sorry if this question seems academic, but most of my footing design experience is with spread footings and this "footing" is really a beam.
