I have a situation where I have a footing with a large uplift, lateral load and overturning force (not an ideal situation). I have the weight of the footing and soil above the footing resisting these forces. The top of the footing is embedded 4’-0” into the ground due to frost concerns.
When it comes to the soil weight above the footing and the design of the footing for stability, would you use the theoretical “conical” soil above the footing or just the project soil above the footing (see sketch) to resist these forces?
