Crispy2
- Jul 15, 2011
- 5
Hi all,
I need to calculate the pressure in a fluid at some fixed distance from a flat plate which is accelerating (normal to its surface) through a fluid.
If you assume the plate to be infinite (i.e. a rigid half-space), then I think the problem can be formalised as a one dimensional problem:
Imagine a rigid, semi-infinite, one-dimensional pipe, with one end which is capped. This could be visualised as a test-tube of infinite height. The pipe is filled with an idealised inviscid fluid of density Rho and bulk modulus B. The pipe is subjected to a constant acceleration A, parallel to its length. How can I calculate the pressure in the fluid at a point along the length of the pipe which is a constant distance X from the capped end?
Does anyone have any ideas or experience with this kind of problem?
Thank you in advance
