flowserve pump madel HPX11A overflow lubricating il
abdo almeskawi
LY
i have a problem with tha pump the pump dont have oil leak and the constant level oil empty added oil many times shown that over flow on pump
The oil cannot disappear, must have a leak somewhere.
The pump doesn't have an External leak. This means your leak is internal.
Seems it's a standard bearing frame arrangement with bearing and seal each end open to atmosphere - any leak should be obvious
Abdo. You need to help us here and provide photo, sectional drawing etc.
You need to do the heavy lifting to give us the information on this particular pump.
