On the left we have a system with a pump and two branches , a pump produces head of 10 bars and Q of 5 m3/h according to the system requirments. On the left the pressure came uot of the pump 10 bars it drops to reach 9 bars at point 3 then the 9 bars drops in branch 1 to reach 1 bar at its end and the 9 bars drops in branch 2 to reach 8 bars at the end , while the flow rate is divided to be Q=2 in branch 1 and Q=3 in branch 2 according to pipe sizing and calculations . Now on the right picture the same system but we adds a resistance ( restricted orfice ) to drop the pressure 2 bars on branch 2 ,, now the pump curve point is the same and the pressure is the same at branch 1 but it drops to 6 bars at the end of branch 2 ... Now the question is the pump still produces the Q=5 as the point of operation doesn't change but at the same time there is much resistance in branch 2 than the previous case , so what will be the valve the flow rate decreases in branch 2 and increases in branch 2 ??
I need to understand this point
