Flow Rate through Smooth Bore Hose 2
Chairs
I assumed this was easy but I'm having difficulty finding the right equation. I need to calculate the flow rate in GPM of a smooth bore hose. The diameter is 3/8", length is 100 ft, inlet pressure is 250 psi and outlet is atmospheric (14.7 psi). The rest is unknown
It's iterative. Assume a v, calculate a v, adjust a v, calculate a v, adjust a v, calculate a v, . . . until adjusted v = calculated v.
Good luck,
Latexman
Need help writing a question or understanding a reply? forum1529
