bdp6632
- Sep 30, 2009
- 14
I have a storage tank with oil elevation as 20m.A pipeline flows from the bottom about 500 m long and I want to know the discharge rate at the exit of that pipe.This can only be done if I know the discharge velocity.I am applying Bernoulli equation on the pipe exit point and tank top. Can I assume that the pressure at the exit of the pipe would be atm.If I don't do this then there are lot of unknown variables in the equation. In my opinion it might not be atmospheric because there will be some pressure inside the pipe on top of the atm pressure even though I am taking into account the losses due to friction and velocity head etc.
