more22
Chemical
- May 2, 2005
- 6
I have the following situation:
We are trying to use an existing pump to transfer liquid to a tank 4 miles away from the pump. At times, the pumping rate is going to be less than the minimum flow required by the pump (a spill back line with a restriction orifice will protect the pump for this case).
I need to install a flow control valve on the pump discharge and need to know how to select the pressure drops for the min, normal, and max flowrate cases.
