IT's probably redundant by now. The frame should have a rim on it about 2" lower from the top of the frame. This is to compensate for the last lift of asphalt. Depending on your design, I would follow th manufacturers recommendations. In general, on roads with a 6" lift, I have placed the frame and cover on top of the first lift of asphalt and then continued with the final lift.
