A quick but unreliable coloration is to consider the compressive strength to be eight times larger than the flexural strength. This ratio depends on the level of strength of the concrete, that is : the higher the compressive strength the lower this ratio becomes. As the tensile strength increases with age in a lower rate than compressive strength.
Because of that and other factors (method of testing, size of specimen, shape and texture of coarse aggregate, moisture condition) , this relation should be ONLY used as an indication not as a decision making.
How ever; an expression used by ACI to relate tensile and compressive strength is:
ft = k ( (fc’)^1/2)
Where ft is the tensile strength, fc’ is the compressive strength and k is a coefficient relating to the factors mentioned earlier.
I used to have a study of the relation between compressive strength and the (flexural ,splitting ,direct) tensile strength tests I will try to find it for you.
I hope this answers some of your questions!
Drop By !!
