You almost shouted, in bold and all caps too??? Is that some sort of internet etiquette issue? I was going to use all double bold, all upper case letters, in 28 point print, and was thinking that would be just a grumpy whisper, given my feelings on the matter. You guys waste your time and effort to try to help someone with what appeared to be some kind of a real structural problem, and then after 13 posts or so he says; by the way here’s the important info. and details about the problem, and it changes almost everything you guys were guessing about my problem. Where is the internet and forum etiquette in these kinds of questions which waste your time, effort and willingness to pass on your knowledge and experience? Particularly, when the OP’er. won’t waste his time to fully lay out the problem, in the first place.
I think we should all take a few weeks off, let every OP go 20 or 30 posts, by which time we might have a better idea what the real problem was, from all the back and forth B.S.; even determine if the participants had a vague idea of the scope and nature of the problem was. Some of you more experienced fellows waste your time giving such good sound basic advice, and then have it turned on its head when all the cards are finally laid on the table. Someone on these forums has a sign-off which says something to the effect, ‘first define and be able to fully describe the problem, then solve it.’ Let’s all start doing that!
