I agree with Connectegr, you are playing with fire when you design a one sided fillet welded joint where the stresses/forces are in tension perpendicular to the weld axis at the root of the fillet weld. Your WT side fillets..., and short returns t&b will not fix this. This area of the weld is prone to almost every possible weld defect; poor fit-up or root opening, lack of fusion and lack of penetration, potential root cracking, etc.; all weakening features along the axis of the weld, and you are trying to apply tensile forces/stresses perpendicular to this axis; whereas shear stresses in the weld and parallel to the axis of the weld are much less susceptible to these same weld quality issues.
A moment on your detail will do two things which are detrimental, and additive. It will flex the flange of the WT in such a way as to cause a bending tensile stress (prying?) across the side fillet welds at their roots, and the magnitude of these tensile stresses will be a max. at the terminations of the side fillet welds. Another location which is prone to weld defects, their terminations. The sum of these two conditions just tends to unzip that fillet weld from the ends of the welds. You could help mitigate the above problems by welding all around on the WT and the seat angle, but this has some drawbacks too. Now the WT has a hard spot at its web and the wall of the HSS will flex w.r.t. the weld root at this point... the same problem as above? Welding around the top corners on the seat angle will as likely as not leave a notch in the top corner of the horiz. leg of the seat angle, a stress raiser right where you don’t want it.
As Ron suggested, 30MAY12, 20:16, however we model it, the joint will take some moment until it starts to yield or fails, how much is another question. And, you must guard against those WT side fillets just unzipping, from the top down. The successful ‘flexible moment connections’ so far, have provided a well defined ‘fuse mechanism’ or yield mechanism and location for this action, away from the welds and pretty much eliminated a weld root or weld hard spot as being a potential failure starter.
