K
KHartline
Guest
I need to model a flexible ground strap in Creo which would be easy enough for one assembly. The problem is it will eventually need to be in multiple assembly with the same part number and I doubt it will ever be routed the same way. So is there any way to build flexibility into it so I can route it differently each time but always have the same part number show up in the BOM?
