Flexible cylinder with stroke limitations
  • Thread starter Thread starter moose021
  • Start date Start date
M
moose021
Guest
Is it possible to add stroke limitations to a hydraulic cylider so when I use it as a flexible part it will stop at the end och send an error message.
/Moose
Yes, it is possible and there's no need to use it as flexible part.
Change the assembly type of the rod to Cylinder thus creating mechanism. Now, go to the mechanism module and choose the cylinder connection in the mechanism tree, RMB and Edit Definition. Now set the orientation and define zero point and stroke (to make things easier, position the rod to the zero point and then choose Set to zero button on the Edit definition popup). For the stroke set the upper limit to desired stroke value. Lower limit is to be set to zero.
You're done.
