Lou Scannon
Automotive
- Feb 11, 2003
- 2,994
Sounds plausible but I haven't come across one. Can you cite a late model application using such a sensor? I'd like to investigate.dgallup said:There are sensors in the fuel line that tell the ECU the percentage of alcohol in the fuel so it can make fueling adjustments. I don't know what principal they are using to sense it.
IF the calibration for E85 is as well optimized as the calibration for petrol, then yes, HC, CO and NOx should all be lower. And then, if CO2 is classified as pollution (which is debated), then cradle to grave CO2 "pollution" might be reduced also, but that is a hotly debated question, due to the existing methods of ethanol fuel production.Mfgenggear said:I would gladly pay the $3.00 for a gallon of E85 if I had a flex vehicle.
plus less pollution right?
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
