Flat Spring thickness/Spring Rate
kevc70
37
I am looking to come up with a relationship between the thickness of a flat spring and the resultant spring rate. For this example, we will assume that width, length, and spring deflection are constant. The material properties of the flat spring is:
UNS G10950 (Pretempered Spring Steel) being stress relieved after forming. Finish to be black oxide.
Obviously, increasing flat steel thikcness increases the spring rate (lb/in), but looking for a formula that relates the two. I've looked into leaf spring calculators but am not confident that leaf springs and flat springs would produce the same results.
Can't you just use simple beam theory from a mechanics of materials book? It seems straightforward enough, P=kx, where k is the spring rate and x is the lateral displacement.
The type/temper of the steel should not matter much if it is in the elastic range. That is, the elastic modulus of steel is about 30Msi.
Brian
Depends on the configuration.
e.g. if you have a cantilevered (///) rectangular plate, then the spring constant is
F
K=Ebt^3/4L^3 ///____________
E modulus of elasticity
b width of plate
L length of plate
t thickness
If the plate is pin connected on both ends and the deflection is
F
in the center ______________
K=4Ebt^3/L^3 ^ ^
Thus for almost any configuration, the spring constant varies directly as the cube of the thickness.
As pointed out, heat treatment and stain relief does not affect E and thus does not affect K.
zekeman,
Be careful. Double Integration method is only accurate for small deflections. One of my textbooks defines this as less than 10% of the length.
A quick glance at my SAE Spring Design Manual shows signs of double integration, but I did not read carefully. It is time for a careful reading of your mechanics of materials text on beam theory.
JHG
If a beam is wide and flat, there is an adjustment required to the regular beam deflection equations. These assume that the tension and compression faces are unrestrained laterally. In a wide thin plate, they are tied together. If I remember correctly, it is a (1-nu^2) factor that gets involved as the correction.
If your application is similar to a reed valve, I recommend measuring the force vs deflect. FEA is not likely to help much, unless you have small deflections. Also, in measuring and in FEA - make sure your force measurement is perpendicular to the surface (which is rotating in the case of a reed valve opening and closing).
