14 CFR 21.31 says this about type design.
§21.31 Type design.
The type design consists of—
(a) The drawings and specifications, and a listing of those drawings and specifications, necessary to define the configuration and the design features of the product shown to comply with the requirements of that part of this subchapter applicable to the product;
(b) Information on dimensions, materials, and processes necessary to define the structural strength of the product;
(c) The Airworthiness Limitations section of the Instructions for Continued Airworthiness as required by parts 23, 25, 26, 27, 29, 31, 33 and 35 of this subchapter, or as otherwise required by the FAA; and as specified in the applicable airworthiness criteria for special classes of aircraft defined in §21.17(b); and
(d) For primary category aircraft, if desired, a special inspection and preventive maintenance program designed to be accomplished by an appropriately rated and trained pilot-owner.
(e) Any other data necessary to allow, by comparison, the determination of the airworthiness, noise characteristics, fuel venting, and exhaust emissions (where applicable) of later products of the same type.
Like many issues with the FAA, the correct answer is "it depends". If the flat pattern is considered by the FAA ACO or designee authority that is approving the data to be required under any paragraph of this regulation or the sub-chapter(s) applicable to the article in question, it is part of the type design. If that authority does not consider the flat pattern to be required by any paragraph or sub-chapter of this regulation, the flat pattern is not required to be on the drawing, but it is also not forbidden. However, placing non-required information on a type design drawing can severely limit you with future changes if it turns out that the non-required information conflicts with a later design change.
You may want to have a conversnation with the FAA/designee who approves the design. Always be cautious, however. Asking any question directly of the FAA or designee always carries two major risks:
1. The FAA/designee may decide detailed investigation is needed into the issue and there may be unintended consequences to your design and/or extra effort required to respond.
2. If you are not the individual in your organization officially designated to be the liaison with the FAA/designee, you will at a minimum irritate the person who is the official liaison. Most organizations with a long history of working with the FAA tightly control who talks directly to them...and with good reason.
