Hy to all,
I have problem with one part, NX doesn't allow command "FLAT PATTERN".
Pipe starts with one diameter and ends with bigger and I make it with extrude + draft feature. Then I add a thickness of 1.5mm, and I use command CONVERT TO SHEET METAL.
But when I try to flatten the part, NX popup with "UNABLE TO CREATE BODY"
Can someone help me with this issue/part?
