Flare Weld Symbol
JanekPop
GB
We use BS EN 22553 welding symbols, but this standard does not seem to have a symbol for a flare weld or a flare bevel weld (which I have seen in an AWS standard).
If I have a joint where a flat surface with a radius meets a flat surface or alternatively 2 lengths of externally radiused box section side by side and I want to weld down the joint between the radii, which symbol should I use from BS EN 22553?
Because I wouldn't mix standards on a drawing normally. Thanks anyway. However, I was wondering, can't my joint be classed as a fillet weld?
