Hi Eng's!
Just a practical question: on a 10" line with meter and valves I want to use a Flange Adapter (UNIFLANGE) as provision for disassembling the items. So there is a short pipe spool with flanged ends - one flange would be a welding neck flange and one would be a flange adapter. Does that one adapter flange is good enough to provide a sufficient gap for taking the pipe spool piece out and back in, with the both gaskets for both flange ends? I have seen people using adapter flanges at both ends - is that necessary? Thanks!
