A question has been lifted in a HAZID regarding an external fire happening in a plant. The discussion then related to the risk of a line bursting due to this fire and the fire igniting the contents of the line and then the risk of flashback in to the atmospheric vessel to which the line is eventually connected.
The line would only be used during on/offloading operations and even though it is purged, there might be low points with flammable liquid that could potentially flash etc. There were also other lines that similarly would not be in continued use but that could have flammable liquids in them. One "solution" that was lifted to prevent flashback in to the vessel (which has blanket gas) was to put a flame arrestor on the line (close to the vessel). The discussion was kind of strange since this could apply to almost any line, whereas the normal use of a flame arrestor (if used at all) would perhaps be on relief vents or similar. Any experience in the forum on these kinds of issues?
