It appear that you are referring to the Code-minimum thickness. This would be the thickness that one would use as a criteria or "flag" that would indicate that "something" needs to be done.
If so, these calculations are typically found in the original fabrication documentation calculations. The method for performing them depends on the original Code of Construction, including the allowable stress basis from the time of fabrication.
