Dear everyone,
I would like to have your opinions on the following issue:
I've seen someone who calculated the first moment of area of the reinforcement about the centroid of the section, using the following formula:
S = -Asc (yc - d2) + Ast (d -yc)
where:
S = first moment of area of the reinforcement
Asc = area of steel in compression
Ast = area of steel in tension
d = effective section depth (from top fibre to tension steel)
d2 = concrete cover of compression steel
yc = distance from extreme compressive fibre to neutral axis
My question is: whether the minus sign ("-") in front of Asc was correct ?
Should it be + ? If it is correct, why would we need to subtract the compression steel component ?
the formula was used by @avscorreia in his spreadsheet
in another thread,
(which has been closed so I could not ask him there directly,
I need to find a correct equation to calculate S to use Clause 7.4.3 (6) Eurocode 2.
Thank you in advance.
NTCONLINE
where:
in another thread,
NTCONLINE
