I have been given a table of fire flows at various hydrants by a city. A column provides a calculated flow rate for the given hydrant at 20 psi, the max fire flow if you will. I cant remember the equation used to determine this rate. I seem to remember it is a form of the energy equation. As with standard fire flow tests, I have static and flowing pressures at two hydrants. I dont want to solve it graphically. Does anyone have this worked out with the conversion factors to get it in standard units? thanks
