Finding global stiffness using abaqus
ssn3
20
Is there a way to find the global stiffness of the laminate for a given structure? I have defined a panel with sections of orthotropic material. I wanted to know if there is a way to obtain a global stiffnes in a particular direction for a structure with different orthotropic materials and orientations.
Sorry if I was not clear enough. Lets say I have a composite for example with different plies stacked up. Since each ply has its own stiffnes (E1,E2,E3) and orthotropic the laminate itself can be estimated with a laminate stiffnes. In this case there will only be 1 set of E1,E2 and E3 for the whole laminate instead of having individual stiffnes for the different plies.
Basically I am talking about the modulus in the 1,2 and 3 direction. I guess I should not have used the term stiffness.
Okay. Well, like I said, you could use nodal output (displacement and reaction force) out of a reference node that is constrained (equation) to the nodes of interest. Then, in the Viewer, you may plot RFi/Ui to get your stiffness.
Are you new to this forum? If so, please read these FAQ:
If I were to use composite layups to set up my laminate is there an easier way to get the stiffness of the laminate?
