I need an infra red detecting equipment for my submarine instrument. My instrument is submarine robot that suppose to searched for leaks from pipelines submerged in dirty underwater condition. My thought is that the infra red would be developed from the hot oil leaking from the pipeline and be detected. The temperature of the pipeline or the exiting plume should be quite different from the surrounding water so that identifying the leaking hole on the pipeline should be easy. The problem is that I cannot find an infra red system that operates underwater. My problem is to lcate the point on the pipeline surface where the leak is occuring. Diver or working ROV cannot see in thsi water. What should I do?
