luizventura
I am working on a hydraulic system improvements. My plan is to analyze the filtration system and make some improvements.
I am filtering oil (ESSO Anti Wear 1376). The system use cardridge filters in the cooling circuit in order to retain particles from main circuit. There are filters on cooling circuit (after main circuit and before heat exchangers) and protection filters before directional valves (only pilot oil valve), and ther is not filters in the main circuit (due pressure and flow surges). All the filters are (today) nominal filters. We do not have any absolute filter in the system.
The main funcion of the hydraulic system is to drive four hydraulic intensifiers. Each intensifier has one sub-system and each sub-system there are two main pumps (PF and PV axial piston Vickers pump), one supercharge/pilot oil pump (double vane Vickers pumps), pressure valves, flow valve (for cooling circuit) and directional valves (main directional and pilot oil valve) The subsystems share the same reservoir and the cooling circuit. Each main circuit has 6" ND pipe and work with 2191,6 l/min (~580gpm).
Is there any relationship between the filtration flow (sum of flow of each filter in the system) and the total volume of the hydraulic system? If possible send the reference literature.
If the information above is not enough, some general rule or guideline for filtration (regarding flow and total system volume) would be usefull.
Thank you and regards
