Please note that for integrally clad plate to SA-263, SA-264 and SA-265, both clading and substrate may be considered in the strength calculations per UCL-11 (c) of ASME Section VIII, Div.1. You may weld the attachment directly to the cladding for the attachment with the fillet weld as shown; however, if the load from the structural attachments is high, you may wish to strip back the cladding and fillet weld directly to the substrate tying into the cladding with a filler metal compatible with the cladding, substrate and the attachment.
