EngineerKojak
A contractor that I work with has apparently cut a 10" wide by 26" deep trench for a domestic water line, just outside of the foundation for an existing house. There's pretty much a vertical cut right beside the footing. It's obviously too late to stop them. How should they fill this trench? My initial thought was a flowable fill, but my concern is that the water content may cause the vertical cut to collapse. I'm not sure if sand is a reasonable solution, or, if it may be possible to do a sand/portland cement mix, and place that in the trench dry? Any thoughts?
