JNR,
Some of our threads are common single point created on a swiss lathe. Those I'm not concerned about. But others are created with what is called a thread mill. I'm sure that in your years of experience that you have heard of this method. But in case you haven't, the bit has many profiles of the exact thread form (pitch, minor dia, major dia, etc...) on it and is normally inserted into CNC. The programmer then tells the mill where to start and how many turns, in a helical path, to take. And just like magic, you have your threads. I must say that not every threaded part we make needs to have this level of detail, but in some cases I find it to be a valuable tool.
Yes, I do realize that I may be overdesigning the parts, and that a simple thread representation my suffice. The real reason I started this thread is because our email server limits us to the size of the files we can send out. Normally I'm sending a few files to our vendors, i.e. parts, drawings and possibly small assemblies. But we are limited to 1.5mb which really stinks. We're a small company and we don't have a T1 or T3 line, we use 2 cable modems at the current time. So our band width is limited.
I didn't want to come across as an anal retentive designer, which is so far from the truth. I appreciate every bit of information that anyone can give me. Im' not set in my ways and I do accept change. Like I had said before, I realize that I need to change my detail styles before I dig myself into a hole of enormous magnitude.
Blair Hollshwandner
Mechanical Designer
Precision Medical, Inc
